2 Replies Latest reply on Sep 8, 2015 9:46 AM by Arvind Purushotaman
    Getting Components other than suppressed from the assembly treee
    Arvind Purushotaman
      I am trying to get the parts from the assembly tree that are unsuppressed. Can you guys help with the mistake. I am fairly new and I am learning.
      Dim swFeat As SldWorks.Feature
      Dim testModel As Component2
      Dim entity As entity
      Dim component As Component2
          Set swModel = swApp.ActiveDoc
          Set swFeat = swModel.FirstFeature
          While Not swFeat Is Nothing
                  Set testModel = swFeat.GetSpecificFeature2
                  If testModel.GetSuppression = 0 Then
                      MsgBox "Part Suppressed"
                  Else
                      Set entity = swFeat
                      If entity.GetType = swSelectType_e.swSelCOMPONENTS Then
                          Set component = swFeat.GetSpecificFeature2
                          MsgBox "Name: " & component.Name2
                  Set swFeat = swFeat.GetNextFeature
          Wend
      The bold sentence is where I am getting an error.
      Thank you,
        • Re: Getting Components other than suppressed from the assembly treee
          Deepak Gupta
          You need to get components and not features
          Option Explicit
          Sub Main()
              Dim Children                As Variant
              Dim swChild                 As SldWorks.Component2
              Dim i                       As Long
              Children = swModel.ConfigurationManager.ActiveConfiguration.GetRootComponent.GetChildren
                For i = 0 To UBound(Children)
                  Set swChild = Children(i)
                      If swChild.GetSuppression <> 0 Then Debug.Print swChild.Name2
              Next i
              Arvind Purushotaman
              That makes sense.
              But the snippet that I gave gets me the component's name when I run only the else loop in If loop that is ,
                              Set entity = swFeat
                  Wend
              Does that make a component a subset of feature?
              If that is so, can we access a component though features?
