After saving your drawing, the text "SEE BOM" jumps outside the template.
the setup is correct, and sometimes it is no issue, but sometimes, it happens as shown.
somebody?
thx,
somebody?
thx,
It looks to me like in the top image you're in edit sheet mode, in the lower image you're in edit sheet format mode. Anytime you're in edit sheet format mode, the entities which exist on the sheet will not show. Right click and go back to edit sheet mode. Select your text, cut it, go to edit sheet format mode, paste your text. Then it will be part of the sheet format.
Could you double click on the text to make sure there is no space before S.
Also can you upload the template to check.
