Hello guys,
I am trying to combine-subtract the fuselage(solid body) of the part attached with an external box so that i can use it for a simulation.
When the body is at 0 degrees the combine-subtract command runs fine. Unfortunately the problem starts the moment i use the
move/copy body command. After i rotate the fuselage 40 degrees around the x-axis then i try to combine-subtract them and the combine fails
with an error message that it will create invalid geometry.
I cannot understand why the first combine succeeds and the second one fails.
Can you please help me out to understand what is happening..?
I have attached the part below..
Thank you in advance
...seems to work fine for me?
