I'm having a bit of a strange issue that I can't seem to fix.
SOLIDWORKS 2014, using the Photoview 360 Add-In, has always worked perfectly until yesterday. Now for some reason, when I hit "Final Render", it freezes momentarily, the Preview Window comes up as per usual, but the Final Render window never actually appears, leaving Preview to eventually form an image.
I tried reinstalling Bonjour and a few various other random fixes but nothing has solved the issue. Hoping one of you guys has had experience with solving this before.
Thank you in advance!
I admittedly laughed at that, yes I'm certain.
That being said however, I've since managed to fix the issue! There seemed to be a temporary config file in Appdata/Roaming/Luxology that was throwing the entire damn thing for a loop. Forcing it to regenerate the config file fixed the issue.
