Hello All,
How to hide/suppress the single feature (like markings, lettering embosses) in any one of the drawing view. (It should the show in other all views except one selected view).
Narender
Hello All,
Narender
I would use a Configuration. You add one that has the features turned off and then your simply choose that configuration for display in your drawing. You do not have to make another drawing.
Thank you for the replay, This is one of the way as you mentioned, but i dont want create a another configuration for this.
There was feature in the pro-e i was checked with it. I was trying to check in the solidworks... actually i need it in SW.
Go to configurations and create a new "Display state". While this view is active, hide body, face, change colors, add transparentcy, ect. This does not work on entire features (geometry changes). In the drawing view select the display state in properties.
If you want to supress geometry-changing features you will have to create a seperate configuration.
For complex models like large assemblies this saves disk space and rebuild times considerably.
