So I've been doing a lot of drawings with slots lately, and I've noticed the dialogue only gives me a tolerance option for diameter in the dialogue box, nothing in the drop down menu for length. The same applied to a CB slot and a CS slot. Is there a way to get that tolerance to display without changing the entire document default in order to display that single dimension, or is this a known deficiency of the software?
Hi Christopher:
A few SPR might be related to the issue you mentioned.
SPR 745722: Hole callout from a hole wizard feature does not have the ability to change the length tolerance/precision
SPR 587635 :Tolerance value of slot hole callout differs from tolerance value of smart dimension on the same hole
Regards.
