I have created a macro to automatically put tapped holes in a plate from a standard mold component I use. I am having issues with orientation. How do I code the taps to be in the correct orientation? In the below picture I have showed my issue. The points that the hole wizard references are within a sketch in the black piece. When the macro is ran the first part that is referenced is the one on the left and the holes are created normal to that plane. Once it starts creating the holes for the last 3 parts the correct points are selected but the orientation is not correct.
Are you creating them in one feature? If yes then it may not work until you a using a 3d sketch option.
