Using Motion, I often get stuck with a simulation that just 'stalls'. Sometimes it's my issues, sometimes it is SolidWorks (I think if you can reboot and run the same model successfully that qualifies as a Solidworks problem). Regardless, it would be extremely helpful if the whole setup could save itself every X.XX seconds so that even if the simulation crashes you could, for instance pick up where you left off.
Also, does anyone know of a way to see what is going on with Motion. The messages I receive are incredibly sparse, just indicating what the integration step has changed to.
are you using basic motion or motion analysis ?
secondly, what size of assembly u are working on ?
