I tried a number of thing. Most of them commented out, ended up using the name to activate the configuration.
I am using SW2011.
There should be a way to get to the parent configuration from the derived configuration even if it means, just moving back up the ladder?
'Sets the active configuration to the named title
'MyConfigurationName = swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name
'swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name = swApp.ActiveDoc.GetTitle() & " - Open"
Debug.Print swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name
'Rename Active Configuration
swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name = swApp.ActiveDoc.GetTitle() & " - Open" ', "", "", 1, swConf.Name, swApp.ActiveDoc.GetTitle())
'(swApp.ActiveDoc.GetTitle() + " - Closed", "", "", 1, swConf.Name, swApp.ActiveDoc.GetTitle())
'Get Active Configuration
Set swConfig = swModel.GetConfigurationByName(swApp.ActiveDoc.ConfigurationManager.ActiveConfiguration.Name)
Debug.Print "My Config :" & MyConfigurationName
'Set swDerivConf = swConfMgr.AddConfiguration(swConf.Name + " Config Name Addition", "Configuration Comment", "User Specified Name BOM", 1, swConf.Name[Parent Configuration], "Configuration Description")
'Add a Derived Configuration
Set swDerivConf = swConfMgr.AddConfiguration(swApp.ActiveDoc.GetTitle() + " - Closed", "", "", 1, swConfig.Name, swApp.ActiveDoc.GetTitle())
swModel.ShowConfiguration2 (MyConfigurationName)
