Hi There,
If I have a part number variable, is there a way that I can assign a unique number to each configuration using a serial number in EPDM.
My last attempts only resulted in a part number being assigned to the main part file. All configurations received the same part number.
Hi Wayne, are you trying to rename each configuration with a serial number? If so, this is not possible out of the box, but could be odne with programming.
If instead, you have a field on yuor data card which is linked to a serial number, then for that field, ensure that "Updates all configurations" is unticked for that field.
Then when you add a file to the vault with multiple configs, each config should get a different number assigned to it
You can see this leads to the following result:
Default config:
and new config:
I hope this helps, let me know if you have any questions.
Kind regards,
Prasad
