Hi :-)
I was wondering if someone could help me out with a problem I've encountered. I want to make a fairly simple joint of 3 tubes on a groundplane. I'm trying to make the drawing so that I can adapt the angles of the tubes to make different configurations of the part.
In picture 1 you can see that the tubes don't allign perfectly. I've been playing around with floating parts in an assembly and found that it is possible to find a sollution where the tubes do fit together(picture 2 shows it's possible). The idea is to cut the tubes using a CNC laser and then weld them together to make the part.
Any ideas on how to draw this?
Thank you so much in advance!
Rob.
Why not try making part with a weldment and 3d sketch. it will even out the corners, specially if theres 3 links coming to 1 point, you could use a 3-way mitre (Weldment Trimming and the 3-way mitre in SolidWorks - YouTube))
Alternatively, make just one part with a solidcore (without making it hollow yet), with the elevated angle you like, then do a circular pattern with equal spacing. Then at the end shell one of the face to hollow it out.
