I have a part where there is an 1/8" hole thru a 7/8" hole and then patterened for 9 instances. My issue is when I create a Hole Table (chart) in the drawing and select the 1/8" hole feature to be included it gives me the 7/8" hole size in the table. How do I get around this?
I've tried selecting both the face, and the hole edge, neither worked.
Hi Tina, can you post an image of the geometry you are trying to show in the hole table, im a bit unsure if you mean you have a nested hole, i.e. a blind 7/8" hole with a 1/8" hole in it? (essentially a counterbored hole) or do you mean the 1/8" hole is radial to the 7/8" hole through its bore?
