Can you control the precision for sheet metal bend line notes in Tools > Options > Document Properties > Tables > Bend via macro? We are currently set at 2 decimal place and would like to change this to none via a macro.
User-preference option for customizing annotation and dimension drafting standards and as defined in swUserPreferenceOption_e; if not needed, then specify swDetailingNoOptionSpecified
Check out this example:
http://help.solidworks.com/2013/english/api/sldworksapi/Get_and_Set_User_Preferences_Example_VB.htm
And try using it with:
UserPref
User preference as defined in swUserPreferenceIntegerValue_e
swBendAngularPrecision
UserPrefOption
swDetailingAngularRunningDimension
