Hi, I have just found a suspicious bug in SW 2015. When I tried to mirror the component about the right (y-z) plane. it was not mirrored correctly.
I have tried to mirror the same component about front and top plane, the results were perfect.
Here is the print screen and the assembly file. You can have a look.
So my question is... how can I solve this problem? has SW published a bug fix about this before?
This is not bug but SW gives you option to orient your model in different orientation. Check attached video on how to fix your issue.
