6 Replies Latest reply on Sep 1, 2015 9:40 AM by Leon Wurr
    swAppearance
    Willie Roelofs
      Hi I'm trying to execute the following macro:
      2012 SOLIDWORKS API Help - Get Appearance Filename Example (VBA)
      At line:
      Debug.Print "First appearance's filename: " & swAppearance.FileName
      I get the error:
      Run-time error "91":
      Object variable or With block variable not set.
      1. File is open.
      2. File is active
      3. File is saved.
      4. File has an appearance
      What am I doing wrong?
        • Re: swAppearance
          Willie Roelofs
          When I hover over swAppearance in debug mode it's been set to "Nothing".
          Am I missing a reference library?
            • Re: swAppearance
              Leon Wurr
              Try this instead:
              ' Preconditions: Model document is open that
              '                has at least one appearance
              '                applied to it.
              ' Postconditions: None
              Option Explicit
              Dim swModelDocExt As SldWorks.ModelDocExtension
              Dim swAppearance As SldWorks.RenderMaterial
              Dim lNbrAppearances As Long, i As Long
              Dim varAppearances As Variant
                  Set swModel = swApp.ActiveDoc
                  Set swModelDocExt = swModel.Extension
                  lNbrAppearances = swModelDocExt.GetRenderMaterialsCount
                  varAppearances = swModelDocExt.GetRenderMaterials2(swThisDisplayState, Nothing)
                  Debug.Print "Number of appearances: " & lNbrAppearances
                  ' If 1 or more appearances where applied to the model,
                  ' then get the filename of the first appearance applied
                  If lNbrAppearances > 0 Then
                      'Set swAppearance = swModelDocExt.GetMaterial(1, "Default")
                      Set swAppearance = varAppearances(0)
                  Else
                      Debug.Print "No appearances applied to this model."
